TSP224 Cam install
8 Second Truck Club
TSP224 Cam install
Hey yall, just ordered my cam from tsp went ahead with the tsp224 cam on a 112lsa, I've pretty much got everything i need for the install, but i was wondering if i should go ahead and order some rod bolts??? Idk exactly how high im gonna spin this thing its stock headed for now ,and ill be running a stock converter for the time being, anybody with some info it would be greatly appreciated !!!
The LS engines are built very strong from the factory. That is why you see numerous people run 10+ pounds of boost on a stock engine. Hotrod magazine made 1200 hp on a stock 4.8L with two 76mm turbos. All they did was change the gap of the top rings and use ARP studs..
With your tsp 224 in the 5.3L I would spin it at 6600rpm starting out, then get it dynoed and if you want to spin it a little higher later on then do it if you want.
How many miles do you have on the engine anyway?
8 Second Truck Club
6600!!!! that should sound healthy i just turned 41,000 miles also talked with texas speed they said i should be fine without rod bolts so soon as the cam gets here ill get it together to the dyno and throw some vids up
jrmchevyman- What kind of numbers are you putting down with your setup
As for a torque converter, if you don't really tow anything I would try and get at least a 10" 3200-3400rpm converter if you are not wanting to go much higher than a 3000. A 9.5" or a 10" would wake that truck up. A 278mm (11 inch) is good if you are on a budget, but you will want more sooner or later.
Yeah Chris at Circle D recommended a 9 3/4 3200 to 3400 stall for my 5.3 with that cam. I'm running 4:11 gears with a 305/50/20 tire but mite put more gear in it later.
8 Second Truck Club
Need some help yall tore into the motor today and the timing chain seems kind of loose to me anybody know if there's suppose to be a little play the trucks only got 41,000 miles on it kinda hard to believe the chains bad already
