TVS1900 5.3L injector size
Old 07-26-2009, 03:12 PM
  #21
Tech Fanatic
MarineBlue03GMC's Avatar
Cool now I just have to figure out what size they are.
Old 07-26-2009, 07:49 PM
  #22
blownerator
BlownChevy's Avatar
Those are the 42 lb delphi injectors.....same ones I made 500 HP with. Like I said, your tuner or your install has some issues.
Old 07-26-2009, 10:12 PM
  #23
Tech Fanatic
Well if those are the 42lb injectors then the tuner or install is definitely the issue. Looking forward to having Magnacharger check it out.
Old 07-26-2009, 11:03 PM
  #24
SuperchargedSS's Avatar
thanks for the info Brian, was wondering what size the new TVS comes with. Is there a difference in black and pink? FWIW, I am glad I got black. Pink just crams my style...
Old 08-04-2009, 11:02 PM
  #25
Tech Fanatic
Just wanted to post an update. Turns out my factory fuel pressure regulator had a bad O-ring that was throwing the fuel pressure off. After the new O-ring the truck is happily makin 429 RWHP and 467 RWTQ.
Old 08-04-2009, 11:09 PM
  #26
glad to hear bud! Happy motoring!
Old 08-04-2009, 11:12 PM
  #27
Tech Fanatic
Thanks SuperchargedSS!! I am so friggin happy I've honestly been in a daze ever since I saw it pullin those numbers on the dyno. Been waiting 5+ yrs to get a supercharger bolted on to this truck!
Old 08-04-2009, 11:14 PM
  #28
I'm in the same boat, waited forever to get my truck blown, and finally happy with the setup. Only one bad thing, one of my knock sensors went bad, so we need to replace it before she'll run 100% again.
Hopefully this weekend.
Old 08-05-2009, 12:27 AM
  #29
Former Vendor
SRT10KLLR's Avatar
The black ones looked like the Marine 42#'s that are direct swap. The pink ones I have seen are bigger and are EV-6(USCAR) so they require pigtails in our trucks.
MarinBlue, if you ever need anything larger than those I have some direct replacement 60lb units.
Old 08-05-2009, 07:16 PM
  #30
Tech Fanatic
Thx SRT10KLLR for now the 42#'ers I have should be good, but when I get a cam I may be sending you a PM
Quick Reply: TVS1900 5.3L injector size
