uppdate on 8.1L injectors
Old 08-08-2005, 08:30 PM
02sierraz71_5.3's Avatar
Originally Posted by Dark Halo
how well would these work on a 6.0 lq9 with cam and heads? or a 408 even?
If you plan on over 400+ hp look else where.
Old 08-08-2005, 08:33 PM
Dark Halo's Avatar
cool thanks where can I find the alternates?
Old 08-09-2005, 01:50 AM
Banned
CAMMIN03''s Avatar
I have them on my whipple set up and they are not even straining.... I am pushing 6-8psi...
They were at somewhere around 82% cycle....
I think they are great injectors
Old 08-10-2005, 03:27 AM
what is you hp at
Old 08-10-2005, 10:39 AM
BeefTip's Avatar
Location: Somewhere between Auburn, AL and Columbus, GA
Im surprised its that high on a 5.3 w/6lbs of boost.
Old 08-10-2005, 02:48 PM
Here is the thing the more power you make the more fuel you need. If he gets his setup dialed in and starts running 13's those injectors arent gonna be enough. Im at 95% at 6250 rpm and I do run 13's he is gonna need more fuel than me because boosted apps like wot afr in the 12's not like me whos afr is 13's wot. I hope Im not just banging keys here.
Old 08-10-2005, 05:58 PM
Banned
CAMMIN03''s Avatar
That was with a af ratio in the 11's like around 11.7
I think?!?
Old 08-10-2005, 06:03 PM
BeefTip's Avatar
yeah i understand that, i was just surprised that those were being pushed that far at his level. Not that he isnt making any power, but if he decides to go up to 10 lbs he will be cutting it very close.
Old 08-10-2005, 06:04 PM
BeefTip's Avatar
I think?!?
did yall have a wideband hooked up or was all that able to be read through hp tuners?
Old 08-10-2005, 06:14 PM
Banned
CAMMIN03''s Avatar
The air fuel was through HP...
He turned it down to 11.7 I think.... I might not be right...
Quick Reply: uppdate on 8.1L injectors
