Valve cover clearence issues
Old 09-29-2010, 07:22 AM
built408's Avatar
Originally Posted by zittman
Would you put the PCV back in it also or not run one at all? I think you would want to pull out as much crankshaft engine pressure as you can.
Don't run it at all. Oil in the combustion chamber can cause detenation in a heartbeat.
Run breathers on each side, or lines to a remote breather tank.
Old 09-29-2010, 09:35 AM
zittman's Avatar
Sounds good. Thanks for all the info. I'm either going to gut the factory VC or buy some taller ones and install breathers on each side. I may hook up a evac set up from my exhaust like my drag car is.
The_W
10-28-2015 09:00 PM
BlackGMC
08-17-2015 07:07 PM
jroctpb
08-11-2015 03:52 PM
low2001gmc
07-21-2015 02:09 PM
Mzay
07-06-2015 11:03 PM
Quick Reply: Valve cover clearence issues
