Valve Events
#21
what I would like to know is how FI, and better yet, 1lb of boost, then 2lbs of boost, then 3lbs of boost, then 4lbs of boost, etc. etc. effects peak VE on the first stroke and what the Math is to compute where max VE/velocity is at xxx degrees of crankshaft rotation.
93pony, cam, camshaft, critical, design, durability, efficiency, engine, engines, event, events, intake, range, restricted, rpm, selecting, valve, volumetric
