Valve spring help! 5.3l
Old 08-09-2013 | 04:05 PM
BwalterChevrolet's Avatar
Default Valve spring help! 5.3l
building a 5.3l with a 206/212 cam and hydraulic roller lifters
heard that ls6 springs will work
can anybody confirm that?
Brian
Old 08-09-2013 | 05:09 PM
86SWB's Avatar
Whats the lift on that cam? LS6 springs are good to .570" max lift
Old 08-10-2013 | 11:43 AM
the lift is 515,522
Old 08-10-2013 | 12:00 PM
Ferocity02's Avatar
LS6 spring will work well with that cam. Any plans for forced induction in the future? If so it would be wise to getting a stiffer spring than LS6's.
Old 08-10-2013 | 06:06 PM
Blackpanther99's Avatar
Agreed^ If not boosting, those LS6s will work very well IMO.
Old 08-13-2013 | 08:18 AM
nahh just naturally asperated. what about pushrods? could you give me a recommendation on size off the top of your head?
Old 08-14-2013 | 06:59 PM
damianldaigle's Avatar
I've got a brand new set if interested PM me
Old 08-15-2013 | 03:57 PM
Camin00's Avatar
Stock max lift is .500, you could probably us them, but I wouldn't risk it. The more heavy duty the valve spring, the more valve train noise you will hear. I think that is why GM put such low lift cam in the trucks, is to keep tq but also to use a real soft springs to keep the motors quiet. You shouldn't need any more than .570 lift, even if you decided later to go to a larger camshaft. The stock runners in the heads flow pretty well until .550 lift, after that the air flow pretty much flattens out, so going with a .6+ lift cam on stock heads is over kill
If the heads are not milled and the stock head gasket size is used you should be fine with the stock 7.4" pushrods. Everybody will tell you to order the $20 comp pushrods checker just to be safe and make sure.
If the heads are milled .025-.03 then you would be looking at 7.375 pushrod, but again every motor is different and in order to get the correct length gotta measure.
Old 08-27-2013 | 01:57 PM
So then what kinda springs should i go with just to be safe? And can you give me a recomendation on a pushrod checker?
Old 09-12-2013 | 02:56 AM
skaffy03's Avatar
Just use the ls6 springs.
GXPJAY
02-13-2022 08:15 AM
chopperloco
07-10-2016 10:45 PM
4B11T
07-13-2015 03:48 PM
Mzay
07-06-2015 11:05 PM
Quick Reply: Valve spring help! 5.3l
