Vhp 228/232 .551 112 Lsa
Old 04-17-2006 | 12:34 PM
  #21
white1's Avatar
Originally Posted by Quik
show me proof of this!!! i heard this rumor many times but not once has someoen back it up. MS3 and Trex along with others are spinning 7k with stock motors. just cause one claimed person did it doesnt mean everyone else will fail. its the same as the TB myth
True. I personally grenaded mine at less than 7k, but overreved it and snapped at least one rod bolt. At the same time though I know too many people consistalntly turning 7200 + on the stock short block. After I blew my 5.3 though the first thing I did on the new engine was rod bolts.
Old 04-17-2006 | 01:16 PM
  #22
Sport Side's Avatar
Originally Posted by white1
BTW you better hope your "super secret cam" Is a bit bigger than a 216/220 if you are planning on handing my *** to me.
It's 'bigger' for sure. Especially the lobes that open up the intake valves.
Old 04-17-2006 | 01:25 PM
  #23
white1's Avatar
He better hope they are over the 226 range. And they better open up a good bit too, like in the .58x" range
Old 04-17-2006 | 01:41 PM
  #24
Sport Side's Avatar
He didn't need a lobe with 226* of duration to surpass .580'' of lift.
Old 04-17-2006 | 05:05 PM
  #25
FarmerBeau's Avatar
Sexy Party Mod
Thanks Kyle.
BTW Matt, you better hope you brought enough "cam" for me. : Need I say more?
Old 04-17-2006 | 05:18 PM
  #26
what upgrades will i need to run over .551 lift?? thanks for all the input guys i love this site, wonderful help
Old 04-17-2006 | 05:36 PM
  #27
FarmerBeau's Avatar
Sexy Party Mod
well you can go up to .600" lift without P to V clearance issues. Comp cams 918 valvesprings are probably the most used and the best for that cam. If i were you i would run 918s with some 7.400" Chromoly pushrods.
Old 04-17-2006 | 07:03 PM
  #28
Quik's Avatar
5 year bitches!
just remember when using a hardend pushrod, the valves will bend before the pushrods. i personally would rather change pushrods then have to replace valves and do head work along with finding new pistons and etc
Old 04-17-2006 | 09:51 PM
  #29
so i believe for my next cam swap ill be going with the 216/224 .551 from VHP it was between that and a tr 224/224 but thanks to 99silverado i have been convinced....thanks to all
wickedRCSB
10-10-2015 09:29 PM
shootermwc
10-08-2015 01:45 PM
Jake75
10-02-2015 02:28 PM
94f150
09-13-2015 06:39 PM
gmcyukon
09-11-2015 10:33 AM
Quick Reply: Vhp 228/232 .551 112 Lsa
