weak or broken valve spring
Notorious BIG
Has anyone ever had problems with misfires and/or backfires and actually found that they have a broken or weak valve spring?
I've been doing some searching, i can't find anyone that actually had a problem, that was acutally resolved by replacing a bad/broken valve spring that didn't cause catastrophic engine damage.
LS motors only , please.
13 Second Truck Club
do a compression test to locate what cylinder has the issue look at valve spring see if its broke, If not broke swap springs to another cylinder retest to see if problem moved cylinder or still exist
If it still exists on original cylinder you have a valve issue or if it has moved the spring maybe weak not closing the valve completely
Notorious BIG
sorry guys, i don't mean to be a jerk but you are not answering my questions. I'm not asking for help troubleshooting just if anyone has actually found that they had a misfire or backfire issue that was actually caused by a bad or weak valve spring.
i've already done all that stuff.
https://www.performancetrucks.net/fo...opping-481263/
I did get a random pop like a backfire, it always occured after a cold start and if I hopped on the gas before the truck warmed up. Now that I read this thread, I dont remember the truck doing it now that I changed the broken valve spring. I always attributed it to being a little rich at idle and the wideband heating up.
PT's Slowest Truck
You said LS only, but I've had a weak valvespring on a small block Chevy that caused the engine to miss, especially under load. (different engine design, but same mechanical concept). It was a frickin' nightmare to diagnose too...I did pretty much what you did, eliminated absolutely everything else until the valvesprings were all that was left...
