what 2 bore a lq4 to
Old 04-14-2011, 12:14 AM
04herod's Avatar
o ya not that it really matters but my set up is a rcsb awd conversion with the lq4swap 3200 circle d converter built 4l65e and a upgraded nvg149. lts 78mm fast intake 60lb injectors -8 fast rails, aeromotive regulator, a1000pump, and -8 line front rear and a custom built cell mounted behind the axles
Old 04-14-2011, 12:16 AM
04herod's Avatar
ok sounds like a clean up and a stock bore forged piston would b the way to go. with all the arp bolts and studs what rpm would u guys turn the motor
Old 04-14-2011, 12:22 AM
Baltimore Whore
Mangled03gmc's Avatar
6500 all day..
Old 04-14-2011, 12:32 AM
04herod's Avatar
sweet any good piston u would recommed.
Old 04-14-2011, 12:52 AM
I have a gauge for that
Atomic's Avatar
Originally Posted by Swerve7rpm2000
If u dont have to bore it dont! No reason to, you will see no difference and if you have problems in the future you have more cylinder walls to work with
this.
No point in scratching for more cubes when you are going FI.
Any of the big name pistons are good...Diamond, JE, CP, Weisco, Mahle...
Old 04-14-2011, 01:00 AM
Mod with training wheels
smokeshow's Avatar
Originally Posted by Atomic
this.
...unless its an LSX block. Then scratching is encouraged
Old 04-14-2011, 01:02 AM
9 Second Truck Club
stock48's Avatar
this.
Autotec/Racetec also makes a good piston. Their machine work is some of the best I have ever seen.
Old 04-14-2011, 01:06 PM
04herod's Avatar
sweet guys thanx 4 ur imput. i ll check sum of the pistons out and c the work and price on them.
Old 04-20-2011, 09:07 PM
gonzo 6.2's Avatar
STOCK48
Hey,have you ever mad a vid of your runs? have you posted any of them? I would love to see a cluster vid 0-115 would be sweet.
SORRY FOR THE HIGH JACKING
Old 04-20-2011, 09:54 PM
black04's Avatar
Originally Posted by stock48
Finally getting the other videos, off the scamcorder. All I can say is FUCKKKKK sony!
The other vids are still uploading, I will add them as they publish
http://www.youtube.com/watch?v=2sp9SNiqy6Q
9.65
http://www.youtube.com/watch?v=L3XOHMlvEV8
Some clips from another thread
Quick Reply: what 2 bore a lq4 to
