what is the biggest cam that i can run in my gen4 5.3 aluminum
i want to know what is the biggest came i can go with in my 5.3 aluminum motor or what will i have to do to make a ms3 or ms4 work
i may be wrong but if i remember right the biggest would be a .604 lift, i believe, im not 100 percent on that though, others will chime in im sure but i know i have saw a member run a cam with that lift in a 5.3
Would peak really high on a small motor like a 5.3L like in the neighborhood of 6500 RPM depending on heads/intake, just make sure and check PTV... if the heads are milled any it probably wont clear without valve reliefs.
so the tsp 233/239 would be a perfect match since it from 1900-6500 and the carb intake will be either a victor jr or performer
this will be a track car 1988 camaro z28 thats why im trying to put a nice size cam in it but retain all stock bottom end and port polish heads
