what is the biggest cam that i can run in my gen4 5.3 aluminum
Old 09-25-2010, 10:35 AM
ls1birdman's Avatar
Originally Posted by 53bowtie
haha would have been good to know it was going in a car instead of a truck....that makes a little bit of difference.
what difference does that make but I don't have the car yet I'm building motor first but if I was to put it n a truck what would be a good truck for racing
Old 09-25-2010, 11:01 AM
dirt track racer 81's Avatar
Originally Posted by grey matter 04
whats this going in?
i hope not a daily driven vehicle
Big ole cam is gonna be a turd in traffic and lowend is not gonna be good
Believe it or not I have my cam in sig with a stock converter until I get another trans but it drives around just fine. Its going to be a turd in traffic if it isnt tuned right.
Old 09-25-2010, 12:16 PM
ls1birdman's Avatar
how do your l92 heads compare to my 799 s
Old 09-25-2010, 03:49 PM
slowlsx's Avatar
why would you want to put a cam that big in a 5.3? do you think its going to really fast? get you a 5000 stall and rev it to 7200 and it might run like a tr228/230 with a 3600 converter. just sayin.. do your research. there is nothing beneficial in running a cam like that in a 5.3 just plain stupid even if its in a car.
Old 09-25-2010, 06:08 PM
ls1birdman's Avatar
ok so i should be looking for a cam around 228-230 something durations.....?
Old 10-23-2010, 12:25 PM
4.8 silvy's Avatar
Default valve
Originally Posted by JS01
Would peak really high on a small motor like a 5.3L like in the neighborhood of 6500 RPM depending on heads/intake, just make sure and check PTV... if the heads are milled any it probably wont clear without valve reliefs.
I have 4.8 862 heads port and polish,mill of
.025 no valves issues 4.8 has flat pistons,5.3 dished pistons. 225/229 581/591 patriot cam,3.73 gear ,lost power a bit
down low, but these babys love rpm's. I did not expect to be a bullet from the hole, but from 30 mph rolls you'll be surprised. Remember a good PCM tune.
Old 10-23-2010, 08:14 PM
10 Second Truck Club
i use a 23x/24x in my 5.3 and no problem
Old 11-07-2010, 10:20 PM
4.8 silvy's Avatar
Default Cam to use
The cam, depends on the modification you make on your engine. I have 4.8 engine run a 225/229 581/591 mayor head work. port, polish, mill, jump compression from 9.5:1 to 10.5:1 . Used this cam because I'm not looking for 1/4
mile times,top end power. this engine it's a fast reving engine and a small one. belive me I was racing side by side with a friend with a camaro he saw 135mph. With a good valentine One radar detector, open highway you'll think you are in a big trunk Camaro. i have seen lots of guys in sports cars thinking, What the ****!!!
Old 11-07-2010, 11:32 PM
iamkeniff's Avatar
biggest ive seen in a truck is a 224/228 112+4 it only went 12.9-13.0 on DRs. my CCSB runs 12.7s with a smaller cam than you're even talking about running and i have a bigger motor. id be scared to run that big of a cam in a mild p&p head 5.3 your need a 3600+ with 4:30-4:56s or hell even 4:88s to make your truck streetable. BUT everyones opinion on whats a "DD" is different. i like my set up but i wish it DD better. i still have to tinker with the tune and possibly add a few * of timing to make it a little faster...we'll see one day!
good luck man! i wouldnt run past a TSP228 with a 3400+ converter and 4:10s
Old 02-11-2011, 04:14 PM
4.8 silvy's Avatar
If you had a good tuner like I did, and I'm using the stock stall, will put a Yank 3200 later, the tuning will let you drive like a DD with no mayor issue.
Quick Reply: what is the biggest cam that i can run in my gen4 5.3 aluminum
