what cam?
Old 02-16-2009, 08:50 PM
one fast ss's Avatar
Default what cam?
what cam would be good for a 408 with tvs 2300 and 4l80e with 2800-3000 stall. Im looking for good street manners aswell as good low end torque? possibly the stock power band with more beef to it? Also i dont want too much of a choppy idle just something to let you know its there.
thanks
Old 02-16-2009, 09:36 PM
sonoma43's Avatar
custom grind...something like a 222/222 or a 224/224 with a 115+2 lsa
another proven cam would be the Vinci "trucker" a little more tame than mentioned above....216/224 .551/.551 115+4 I believe
Old 02-16-2009, 10:03 PM
SynergyV8's Avatar
I'd have to agree with sonoma43, the last thing you'll want is a long duration big overlap cam with the supercharger. Let the supercharger do the work up there, build the 408 for that heavy torque robbing 4L80E and AWD system. The Comp Cams XER273 comes to mind, except custom ground on a 116+2 lobe separation angle to reduce overlap and idle smoother.
Old 02-16-2009, 10:59 PM
fish5225's Avatar
We went with the 226-238, 601-601, 114 LSA on a 408 with the 1900. It seems to work extremely well. Good manners on the street till you mash the pedal. Here is the dyno graph. What heads are you running. My builder ported some LS2 heads that flowed great. With that 2300 you will need a bigger cam like this one to make it run.
Old 02-17-2009, 08:47 AM
im running ported lq9 heads with retainners and updated 918 springs. I think with that cam i woild have to up to dual springs?
Old 02-17-2009, 08:56 AM
allballz57's Avatar
Nice looking dyno sheet,I am putting together a 408 w/PRC stage 1 heads and custom grind 236/236 114+4 .617,617 cam.I am running a D1SC procharger with it. What kind of boost was he seeing on the dyno run?
Old 02-17-2009, 01:13 PM
what about 224/230 .612 .612 116 LSA?
Old 02-17-2009, 03:08 PM
SynergyV8's Avatar
Perfect.
Old 02-17-2009, 05:07 PM
215/230 .629 .592 117 LSA?
Old 02-17-2009, 05:23 PM
SynergyV8's Avatar
I like the 224/230 .612 .612 116 LSA version you found. I think it's more of a supercharger cam than the 215/230 you just found.
Quick Reply: what cam?
