What cam for a ecsb lq9??
Old 12-03-2012 | 02:48 PM
Gypsy06vortecmax's Avatar
Default What cam for a ecsb lq9??
I got a 06 ecsb vortec max with bolt ons it's my dd so I wanted to stick with a 3200 stall but not sure what cam would make good power to have a daily race truck hahaha my tuner was saying a 228/228 112lsa what is the pros and cons if any in that cam or is there a better cam for my truck for what I want very confused don't really know to much about cam talk
Old 12-03-2012 | 03:27 PM
Camin00's Avatar
you first have to ask youself do you want more low end tq or top end hp
The larger duration you go the more your moving the power band up the rpms
The 228/228 he mentioned would be a pretty badazz cam. That cam is going to lean more towards top end.
Idk if I would go any larger than the 228/228 for a dd
You could also look at some thing with a split pattern like 216/224 for example should help keep lowend tq and topend hp also would put you in a good postion for a supercharger later down the road
Just do a lot of research looking up dyno charts track times of cams in 6.0s
It's better to under cam than over cam for a dd
Old 12-03-2012 | 03:39 PM
03sierraslt's Avatar
All good advice posted above, what exact bolt on's do you have? I would also go with a split duration but specs depend on what you want out of it.
Old 12-03-2012 | 04:17 PM
I do a lot of roll racing do you think it would be good for that with a 3200 stall or maybe a 224/228 would be better??
Old 12-03-2012 | 05:33 PM
Mangled03gmc's Avatar
Baltimore Whore
Texas giant :d
Old 12-03-2012 | 06:52 PM
Camin00's Avatar
224/228 would be an awesome choice!!!
If you were on a stock stall I wouldnt go larger than 220/220 but you not so you can go with a larger cam
Old 12-03-2012 | 10:46 PM
zero2sixT's Avatar
I wouldn't be afraid to run the 228/228.
What gears and tire size? You planning on ported heads?
Old 12-04-2012 | 02:13 PM
I got stock 17s and 3:73 and port the heads in the Future I'm gonna run the 228
Old 12-04-2012 | 05:20 PM
Camin00's Avatar
Your going to love spinning all the way through 1st gear with that cam haha
post us some dyno #'s and possibly a video when your done.
Old 12-04-2012 | 05:36 PM
Camin00's Avatar
So I stumbled across this video of the 228/228 .588/.588 on 112Lsa i know he has LTs efans CAI 4.10s idk what size stall he is running
He is running high 12s N/A
to big of a cam for dd in my opion for the 5.3L but listen to your tuner he knows what he is talking about. Your going to love it in the 6.0L
enjoy
Camera mounted vid - YouTube
