what to do for a safe 7000rpm on 5.3/6l80e
When I started reading the original post, the first thing I thought is the cam was too small for that many RPM's. If you have your heart set on turning it 7k, then I would get a bigger cam. With that being said, I would keep that cam and keep the RPM's down. You will more than likely go faster with that cam in your combo. 5600 lbs is fairly heavy, and you will get more use out of the lower torque that your described cam will offer. I would change gears as previously mentioned.
I honestly wouldn't opt for 7000 rpm, especially retaining a stock balancer. You're going to start throwing A/C belts and stuff.
I would go for a slightly heftier cam than Pat spec'ed you. No more than a 225/230 on a 112+3, and a 3000 to 3400 stall. A great trans cooler setup, and gear change would be beneficial as well.
this is the truck 427 lsx stock 6l80e, in the vid it say's its a 408 but iknow it isnt
408 GMC Sierra VS Chrysler 300C SRT8 - YouTube
so you guys think the cam wouldent die on me with long climbes @ 6500rpm shift?, my truck weighs about 5600lbs
kind of slow for a 427 imo
compcams 219/222 ,.606/.601 , 111+4 lsa, 107icl
patriot extreme dual gold valve springs rated at .660"
pat specd me the cam and i said i want a 6500rpm rev limit
now even though i didnt install it yet i want more rpms
would this cam give up on me befor 6700-6600 or even 6800rpms?
what about valve float?
i heard the ls1 floats @ arround 6800rpms?
If your worried about valve float I would get rid of those heavy dual springs and put on a set of beehives, which are more approriate for that cam. Do you have hardended pushrods?
Like said before, it will spin 7000 but your power will be far past peak and youll be slowing yourself down.
How have you setup the springs you have now?
What heads?
zblee
11-11-2015 12:41 AM
carid
10-01-2015 09:22 AM
