what does burnt valves sound like?
Originally Posted by 02sierraz71_5.3
If your burning antifreeze youve got alot bigger problems than valves
do have whiteish bubbles in the oil or does oil end up in the coolant reservior?
No i was just asking for my information. Just curious.
Truck addict
turns out i believe i have a burnt piston as suspected. i'll be pulling the motor and checking everything out. going back with a punched out 6.0. in the process of looking for pistons, rings and rods. should be a fun build
Fixin my 6.0l Valves as I speak
Originally Posted by onebadrubi
will a burnt valve throw any codes? What about oil consumption or anitfreeze?
My 6.0L consumed oil (1L to every fill up eventually) with no smoke or eventually a little smoke and an engine with no ***** everything else said in this disscsion is right on the money
I had 30 psi compression in cyl #7 and it was my exhuast valve
6.0L rebuilds are expensive I know , I would take a couple hrs and check heads first, from discussion with other and after seeing the internals of mine your bottom may be in good shape
Truck addict
as randy stated, i was indeed hard headed and ran it kinda hard racing a L. i won, but i lost at the same time. but i'll end up with a stronger motor for the most part.
If it feels like it is runing ok and you get up next to a Lightening and then the ego takes over and
Truck addict
Originally Posted by TurboGibbs
Damn dude. My first thought was...Dumbass! but then I reflected back and realized I have done equally as dumbass of things.
Leakdown test will tell you if it's a piston or valve. If it's the valve, you'll hear air coming out of the exhaust port. If it's a piston, you'll have air coming out of the crankcase.
gaps
10-15-2015 02:53 PM
lxcoupe
09-11-2015 03:17 PM
Brandonlflr12
09-09-2015 03:54 PM
