What are everyone's thoughts on big cams and loss of low end?
Old 08-01-2009, 03:17 PM
  #31
Banned Scammer
scotthughes's Avatar
it seems like alot of people on here are against the z06 cam. but everyone ive ever talked to had loved them....which makes me not know what to do. im going to put one in anyways. ill find out for myself.
Old 08-01-2009, 08:57 PM
  #32
06 4.8's Avatar
Well i def think my cam KILLED low end last night I had a best of 2.7 60ft. where pre cam it was a 2.3 and I can feel a lowend loss! yes I know i need a verter!
Old 08-02-2009, 03:23 PM
  #33
zippy's Avatar
Compression is the biggest reason for a loss of torque with a bigger cam. Here is the dyno sheet from my 5.3L. My bigger cam 5.3L even without headers makes decent torque down low with a fairly flat torque curve.
http://pic50.picturetrail.com/VOL440.../326634108.jpg
My wifes Tahoe with a TR224 on a 112LSA in it has no problem at all with torque. Here is a video of it pulling a trailer with the back of the Tahoe also loaded full pulling up hills. Note the rpm, throttle percentage, etc. Even in overdrive at 1700rpm it was fine if I'd trusted the stock trans to pull i overdrive.
http://www.youtube.com/watch?v=iea_VLvETi8
Old 08-03-2009, 05:28 PM
  #34
nonnieselman's Avatar
Z06 cam for NA or boost?
For boost they have been somewhat proven, but there are better cams out there but of course they are goin to cost more.
Lownslo06 has one in his LQ4, i wish we had a before and after but after some tuning it did wake up. and it seemed to pull to 6300 fairly well.
I wish we could have a before and after the cam with the turbo also.
Old 08-03-2009, 05:37 PM
  #35
FormerVendor
Sales2@Texas-speed's Avatar
We've done some engine dyno testing that you might find interesting.
Baseline is the stock LS1 camshaft. The combo is Kooks 1 7/8" engine dyno headers, stock LS1 long-block with 853 casting heads, 85mm MAF, and then the cam swaps with tuning for each swap.
After creating these baselines we tested lots of new camshaft combos & settled on the all new TSP 224/227 camshaft using all new custom Texas Speed lobes. The new TSP camshaft is a 224/227 .615"/605 112. This camshaft helps to maximize power potential using 224 intake duration.
*also included is the new 224 TSP lobe as a single pattern** (run 59)
Silveradorst07
12-31-2015 12:04 AM
steves86ta
07-28-2015 10:21 AM
low2001gmc
07-23-2015 05:10 PM
GreyChevy
07-07-2015 08:57 PM
Quick Reply: What are everyone's thoughts on big cams and loss of low end?
