what exactally do i need?
Old 08-14-2009, 10:16 PM
5speedsilverado's Avatar
Default what exactally do i need?
ok, so i want to put a cam in my truck, i was looking at the comp cams XFI RPM 220 224 .530 .534 112° so what all would i need with that cam?
here is a link to all specs
http://www.compcams.com/Cam_Specs/Ca...csid=1087&sb=2
Old 08-14-2009, 10:29 PM
AndysC3's Avatar
Ls6 springs, hardend pushrods, and a retune
Old 08-14-2009, 11:06 PM
I have a gauge for that
Atomic's Avatar
^ yep
secondary things like an oil change after 200 miles, coolant and distilled water to refill, new crank bolt, new water pump and timing cover gaskets...
Old 08-15-2009, 07:34 PM
ok, so why do i need a new water pump and timing cover? also part numbers would be much help, thanks
Old 08-15-2009, 07:36 PM
Wearin' da big hat
00ChevyScott's Avatar
new water pump gaskets and timing cover gaskets just because it's a good idea.
You can pick both of those up from any local parts store, they're usually in stock or readily available.
Atomic's Avatar
Just the gaskets, not the whole parts. They are fragile and are not reuseable, although you could risk it if you are really cheap. Texas speed and performance sells a simple swap kit with the gaskets and bolt included.
Old 08-15-2009, 08:44 PM
lol i didn't see gaskets after that so is that cam really good up to 68000 rpm's? also how would i install one of these rpm gauges?
one more thing, does any one have part numbers?
http://prosportgauges.com/blue-tachometer-52mm.aspx
Old 08-15-2009, 10:02 PM
Mr. Obvious
nightrunner's Avatar
what is REQUIRED is some LS6 valve springs and a retune. along with the gaskets and fluids
some additional parts that you can add and are easy to go ahead and add now are
pushrods
timing chain
oil pump
better roller rockers
lifters, if you are going to pull the heads, you dont have to, btw
that cam might pull to 6800 rpms but sure wont go to 68000
hook the tach up to a 12v source, ground out to frame, and the signal wire can hook into the tach signal wire coming out the back of the cluster.
on the tach signal wire, i just searched to be sure and everything i can find says the white wire, but i could have sworn i hooked mine into the purple wire, but its been so long i cant remember
Old 08-15-2009, 10:47 PM
dug
Banned
dug's Avatar
you dont need hardened pushrods but you want to make sure the stockers are the right length.
Old 08-16-2009, 08:09 PM
zippy's Avatar
I would get some LS6 springs and the GM cam change gasket kit. Get some Dexcool, Water Wetter, and stuff for an oil change and you'll be set.
Quick Reply: what exactally do i need?
