What happened cam and lifters?!?! boosted
Old 04-25-2013 | 01:50 PM
  #51
TimDave217's Avatar
sweet thanks for the info!!!
Old 05-02-2013 | 11:25 AM
  #52
Stampede4ever's Avatar
So, did I miss what caused the damage?
Thanks.
Old 05-03-2013 | 01:14 PM
  #53
Area47's Avatar
what happened to the other two motors you had in there?
Old 05-03-2013 | 09:18 PM
  #54
blackbalt's Avatar
Looks like you weren't running enough boost.
Old 05-07-2013 | 11:35 AM
  #55
TimDave217's Avatar
what i think caused the damage was one lifter that actually broke where the roller pin goes through, basically stabbing the cam and setting it off compared to the other lifters then the lifter directly across from that one ended up seizing in the lifter bore which stopped the cam from spinning this way and sheared the cam bolts and all the rest was history. it was both the very front lifters. now i need to re-sleeve the one lifter bore because of this.
Also i only had one motor in before this one, which was just the stock iron block.
and i wasn't making enough boost only 14 lbs so that might have been the problem
Old 05-07-2013 | 11:37 AM
  #56
TimDave217's Avatar
Also this is just what i think caused it, and i feel its pretty accurate from how everything broke. and how things were sitting. but it definitely could be wrong.
chopperloco
07-10-2016 11:45 PM
greedygenius
09-03-2015 07:51 AM
lxcoupe
07-30-2015 03:42 PM
Suburban2500
07-19-2015 05:50 PM
GRRR65GTO
07-10-2015 09:27 PM
