What HP am i looking at, at the crank with my 5.3 with the mods i have now?
formerly 2low4nd (11-08-2011)
2000 RCSB 2wd 5.3 with 59,000 miles.
Thunder Racing TR224 on a 114 LSA 563 lift cam
Thunder Racing 7.4 pushrods
PAC 1218 single beehive valvesprings
Pace Setter Long tube headers
Cat delete / Hp tuner
4000 Stall converter
NX 100 Shot plate kit
The true dual 3" exhaust isnt installed yet with the Magnaflow race bullet mufflers.
stock 373 gears with rear locker, i have a set of 456 i might install next summer.
Just curious guys.
Any input is welcome.
Thank you for your time.
Mike.
Just curious guys.
Mike.
Just curious guys.
Mike.
Just curious guys.
Mike.
Just curious guys.
Mike.
Just curious guys.
Mike.
As for RWHP depends on what type of dyno you go to or compare. Some dynos like the dynojet, dyno higher than others which basically means the numbers are inflated a little.
On a dynojet I'd say you prob have around 340-350 RWHP / RWTQ not spraying.
Those TR 224 cams dyno roughly the same as a TR 220 they just have a few more hp up top.
Wow, i wasnt expecting that much. Impressive to hear. What does this setup run in the 1/4 mile in perfect conditions perfect tune? Hooking up that is with 60 ft times. All of this of course is just generalizing. I unserstand you southern guys tend to run about 1 sec faster then us nothern guys.
Just curious guys.
Mike.
Just curious guys.
Mike.
there were some shifting problems on that run too. it hit the limiter on the 1-2 shift and i had to pedal it to get it to shift. also, wheatley and i have hours of logging since then as well as some caltracs, and a ported tb
i have a 3200 stall converter, but it needs a 3600 or so...
wheatley is getting me a nitrous tune this thursday and im going to the track sunday. i will report the times. oh this will be on a 100 shot as well.
