what springs for xr265hr????
Old 05-14-2009 | 11:52 PM
Default what springs for xr265hr????
ok, heres is the cam im deciding on for the ole 4.8.
54-412-11 XR265HR 265/271 advertised 212/218 @ .050 .522/.529 114° LSA
can i use some ls6 springs i have, or do PAC1218's? Im gonna order some 7.4" hardened PR's, but not sure on the springs.
Old 05-15-2009 | 12:17 AM
D_reks{5.3}'s Avatar
You CAN use ls6 springs and they should be fine. But if you want extra security then get the PAC's
Old 05-15-2009 | 02:56 PM
fastrt's Avatar
11 Second Truck Club
do pac's, and then if you want to go bigger on the cam, then your covered on the springs....
Old 05-15-2009 | 03:36 PM
Mangled03gmc's Avatar
Baltimore Whore
Ls6 will work, but i would get a heaver spring in case you ever want to up cams..
Old 05-15-2009 | 04:28 PM
LMSeven's Avatar
LS6 springs for 2 years or so for me. Can't go wrong with stronger springs...depending on future goals.
Old 05-15-2009 | 05:32 PM
budhayes3's Avatar
PT's Slowest Truck
I've been running LS6 springs for a few years, but my cam's puny. This 5.3 shouldn't ever see a cam upgrade while it's in my truck though...there's an LQ9 in the works As for the 5.3...maybe it'll end up in a street rod some day (or in the classifieds)
Old 05-15-2009 | 07:18 PM
Tootall's Avatar
I've got a set of NEW LS6 springs Holler if you're interested
Old 05-15-2009 | 09:32 PM
lucky77's Avatar
Banned
ls6 yellow springs are rated at .550 correct ?
Old 05-15-2009 | 10:37 PM
Tootall's Avatar
560-570 lift
all depends on what the seat pressure needs to be for the cam
Old 05-18-2009 | 09:58 PM
MPFD's Avatar
I got the same cam and I'm running yellows. It will be fine no reason to buy million dollar springs with that cam. If you decide to upgrade then buy Pacs later.
