whats diff between truck 6.0 & ls2
Whats the difference. Im looking for 400+ horses. I want an ls2 but in the meantime I was wondering potential of the 6.0 truck motor. These truck motors or much more affordable
I know truck motor is cast iron vs ls2 aluminum
High on diesel fumes
Truck 6.0 is iron block, GENIII engine. LS2 is aluminum block, 4th gen series. LS2 is higher compression. GENIII motors have rear cam sensors and the knock sensors are in the valley cover. LS2s have the cam sensor in the timing cover and have knock sensors on the side of the block IIRC. Some of the LS2s have a different reluctor wheel on the crank. I can't remember the tooth count off-hand. LS2 has 243 heads, truck motor has 317 heads.
Both have equal potential for making power. It all depends on how they are set up.
