whats a good mild cam for 08 5.3?
alright, ive also heard some people running into problems cause of the dod these trucks have?! would that only be a problem for the tune.. or cam install also?
Where's the Beef?
Tuner can adjust or disable the DOD. However you will want to put in some LS7 lifters because the lifters they come with stock can't handle after market cams for too long.
7.3xx pushrods but I'll have to go check the actual measurements in another thread in a bit.
Edited size. Typo'ed
Where's the Beef?
Yes. There are several threads going right now where the 7.4's are either causing a tick or eating up the lifters.
The LS7 lifters are a little longer than stock.
Here's a thread that F4tal found
https://ls1tech.com/forums/generatio...uestion-2.html
If you use Ls7 lifters you'll want to use 7.35 pushrods.
i know that tsp has a DOD delete kit available, but there is another question i have is there any lifters available that the use of 7.4 pushrods is fine to where you wont need to get some shorter pushrods?
oh definite change of pushrods but i have the hardened 7.4 should i just sell these and get the 7.35 then?.
trying to keep this short instead of stealing this thread but i think it could be helpful to all DOD cam swaps.
