What's the least path of resistance?
What about just putting weld on the broken off stud. Use a mig welder, and build up weld on the end of the stud so you can grab onto it with a pair of vice grips. The heat from welding will help it break loose.
I feel your pain!
Had the very same one break on my truck, actually I found it already broke off in the head.
So I pulled the head and tried a E-Z out and just like you it broke off lol. So after hours of using a dremel to grind through the hardened E-Z out I finally was able to get a larger E-Z out in far enough to catch.
If you can't weld a nut onto it your going to have to pull the head if you want it removed.
After instead of using studs I used the ARP cam bolts for LS motors, they also work for header bolts.
The Stage 8's are nice but can be tricky getting all the retainers on. My ARP cam bolts have not loosed a bit! Using the Ultra-Torque from ARP and torquing them down real good is all they needed with the factory MLS gaskets. Now with a graphite gasket or paper I could see them backing out on you, or if you didn't snug em down enough.
anyone have a picture of how this kit mounts? i'm not picturing it in my head and it could be a lot easier than pulling the exhaust and welding on nuts.
