What's the least path of resistance?
#21
I have seen so many 5.3L that have that same position bolt broken off. Idk if it gets hot in that little pocket and it makes the bolt weaker than the others or what.
I tried drilling out the bolt on a set of heads I picked up and the drill bit broke off in the bolt......Talk about a real problem. After dulling 3-4 other bits I found a glass drill bit cut through the broke off drill bit and bolt like butter, and then I re taped it and problem solved.
If you don't want to remove the head than I would live with it or seal it up it leaks
noproblems209
08-10-2015 06:57 PM
