Who Has The Biggest Cam In A Ls1 Or 6.0???
#51
ms4 should have 4000 and around 410 gears. thats based off using 26" tall tires
but with your thin head gasket you might not be able to run any donkey d1ck cam. since the ms3,ms4 and Trex were based around a stock motor at stock specs.
youll easily pick up power. your launching higher with a better torque numbers your 60' if you can grab should be noticed.
if small cams were the ticket then no body would run a larger one. with your 11.1 ls1 you should do fine if you have the mods for the ms4. it requires a free flowing exhaust to take full benefit of the topend rush it has
#53
