who is running a big cam w a stock 80e converter
Old 10-03-2008, 09:08 PM
13 Second Truck Club
726.0chevelle's Avatar
Default who is running a big cam w a stock 80e converter
i have a 6.0 and a stock converter 80e is there anyone running a bigger cam with the stock converter. i know about cams and stalls and have pushed the limit in the past just don't know how these newer motors act. the main reason i asked is bc i have friends with 2500hd and it feels like its stalls up a bit more than a 60e
Old 10-04-2008, 07:46 AM
BigCountryx's Avatar
Mine would brake stall to 2600rpm before the blower. It sounds like that is a lot of stall stock, but with the tall first gear in the 80, it's needed.
Old 10-23-2008, 04:38 PM
2manycars's Avatar
Anybody else have any ideas on this? My 01 w/4L80E is looking for a cam. It has a stock long block soon to have a full exhaust and cam. With a stock converter and a good tune can you get away with a 218/224 .563"/.570" 116+4? I feel like the wide LSA can keep my overlap down enough for a smooth enough idle. Any opinions or experiences?
Old 10-23-2008, 05:19 PM
im running a 212/218 on a 115 lsa with the stock converter on my 2500hd feels pretty good to but i also have long tube headers,electric fans,cold air intake,
Old 10-23-2008, 07:11 PM
2manycars's Avatar
Thanks for your input, I appreciate it big time. My truck came with a K&N FIPK on it and my electric fans should be spinnin' next week. Full exhaust including headers will be installed at same time as cam and truck will be taken directly to be dyno tuned. Is your truck tuned?
Old 10-23-2008, 08:00 PM
GMCtrk's Avatar
How much does your chevelle weigh? I'd go with the TR224 personally.
Old 10-23-2008, 08:55 PM
id say 3800 i plan on runnin 410s or 373s with a 275 45 17 tire
Old 10-23-2008, 10:47 PM
2manycars's Avatar
Sorry dude I didn't mean to try to hi-jack your thread, I thought it was dead after I found it in search. However your project is sweet and since we are looking for the same info I will stay tuned and if you don't mind ask questions also. Also I would go 3.73's, my 2 cents.
Old 10-24-2008, 12:23 PM
zippy's Avatar
One of my friends ran a 233/239 in a 2500HD. It was a bit much due to not enough stall. I have set up a couple of 2500's with the same cam I have. It is just on the edge of too much cam for the stall, but still in range.
Old 10-24-2008, 05:07 PM
2manycars's Avatar
So you were able to get by with a stock 4L80E converter behind a 222/224 112LSA cam. Did any of these trucks run stock heads and compression ratios? I didn't think you would be able to get away with that much overlap with the rest of the longblock being factory.
Quick Reply: who is running a big cam w a stock 80e converter
