who is running a big cam w a stock 80e converter
Sorry dude I didn't mean to try to hi-jack your thread, I thought it was dead after I found it in search.
However your project is sweet and since we are looking for the same info I will stay tuned and if you don't mind ask questions also.
Also I would go 3.73's, my 2 cents.
![Embarassed](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_emb.gif)
![Winky](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_wink.gif)
single digit dreamer
what are you hopeing the cam will do for you? a higher stall will give you more et than a cam. i would go for a stall first unless you need to tow over 5000lbs often.
i ran a 234/232 600 lift 114 sep cam with a mild stall and it was still a dog till 4200rpm. it picked up great power up top but waiting for it to hit in 1st gear took forever.
i am not really looking for a strip car. i am trying for an all around car. i am going for the restomod style. i want it to be strong but i dont like the mushy pedal of a high stall. i am just trying to get an idea of people that did cam swaps and kept their stock verter and how that vehicle did.
![turd](https://www.performancetrucks.net/forums/images/smilies2/turd.gif)
The question is what size cam can be run with a stock converter and with said size cam what modifications were performed.
yea 317s for now once i get the car running and on the road i plan on cam and possibly some mildly ported 243s. I just want to leave the motor alone to make sure all my wiring is correct i just rewired the whole intire car plus added the aftermaket ls wiring harness
I'm thinking you should be good but I'm not sure either
. I love the fact that the cam you are looking at doesn't have a silly lift that will do nothing but wear out valve springs on a street engine.
![Icon Confused](https://www.performancetrucks.net/forums/images/smilies2/icon_confused.gif)
![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
