Will LS1 rods fit a 5.3L?
Old 03-07-2014, 11:41 AM
Chiphead's Avatar
Default Will LS1 rods fit a 5.3L?
I need stock rods for a 5.3L.
I see LS1 rods for sale on ebay but I need to confirm that they'll work for my mild build. Can somebody educate me on LS1 and Vortec 5.3L floating rods?
Are LS1 rods and 5.3L floating-pin rods dimensionally the same?
Will LS1 6.1" rods fit a 5.3L with stock-type floating pistons?
thnx!
Old 03-07-2014, 12:16 PM
dirt track racer 81's Avatar
Ls1 rods are a pressed pin and same as the older 5.3 rod
Old 03-07-2014, 04:14 PM
Chiphead's Avatar
So what are stock rods that are 6.1" long, 945" wrist pin with brass inserts in the small end for floating pins??
I sent a message about casting numbers but no response yet.
Old 03-08-2014, 09:44 AM
11 Second Club
batboy's Avatar
Stock rods are 6.098" long.
Old 03-09-2014, 03:58 PM
TexasGMC08's Avatar
Yes, if your going forged 6.1 with a Press Pin 945 if your using LS1 pistons. If you are going to bore a 5.3 to 5.7 specs
Old 03-09-2014, 09:11 PM
Chiphead's Avatar
I don't think the rods I'm looking at on ebay are forged. They are listed as stock used LS1 6.1" (likely 6.098 but the seller rounded up) and the small end has a brass insert that I'm pretty sure is for a floating pin. If they're not LS1, then what could they be?
I'm just looking at a stock 5.3 rebuild starting with a 4.8 because used 5.3 or 6.0's don't exist where I am. The online junkyards want $600+(plus shipping) for a freaking 5.3 core. Is there a way to go to 5.7 with stock rods and cheap pistons? I don't want to spend more than $450 for rods and pistons. This is an el-cheapo build where I'm scrounging used or rebuilder quality new parts to put an engine together. So I'm looking at used rods and hyper pistons on the internet. Problem is, I've never built an LS before so I'm a monkey with a pipe organ. I see LS1, LS3, LSX and I have no idea what fits what. I've got a couple of the builder books and I'm reading here to learn. I appreciate the info you guys can share...
Old 03-10-2014, 11:28 AM
tim wellington's Avatar
Default 5.3
where are you located
Old 03-10-2014, 07:15 PM
Chiphead's Avatar
South carolina. I've got a good block but I need a rotating assy. I guess it's a great way to learn... or get screwed depending on one's outlook...
5.3Okasai
03-09-2022 01:07 PM
Corvette454l88
09-01-2016 01:24 AM
5.3lSilverado
25
08-29-2016 12:48 AM
Denali08
08-09-2015 04:34 PM
FlowmasterMufflers
07-17-2015 03:26 PM
Quick Reply: Will LS1 rods fit a 5.3L?
