will this work?
will this work?
well guys i justed ordered some 41" HEAD gaskets and im was woundering if this will work with a gt2-5 222/222/ 566 566. I know i could do the whole clay thing but im trying to save time. Also will a 7.400 push rod work.
I believe that's an .041" gasket...a 41" thick gasket might drop compression just a tad
You will have no problems with the valves touching the pistons until you get to the ~.610" lift range with that gasket....
Banned
1 Post
Yelo is right i have 216/220 witch is 525/532 with 1.85 rockers that gives me around 579 lift and when i did the clay i still had 110 ths till valve hit piston and that is with soild roller lifters
Stainless Works
04-10-2016 04:34 PM
atxlt
07-20-2015 11:06 PM
Nimoryan
07-05-2015 03:50 PM
