wow! my valve broke
wow! my valve broke
i am really let down that GM chose to go with such a cheap valve in these heads.
the valve stem broke in my engine last week, some of you already knew that... but i am still irritated about it. luckily though, since i put a cam in the engine, warranty did not cover it. YAY! i guess i knew that going into this, but i hoped that they would cover it still, since it was a defective valve.
i was cruising home about 50 mph when it happened, sounded like a bucket of bolts in there. the stem broke right under the retainer, i have the piece in my pocket actually. the locks and retainer are still attached, just a clean break on the stem. you can see the shiny and dull spots on the stem where the break occured, and it looks like a cast valve... like some kind of shitty metal was used to make this valve with.
oh well, i found a built 377 with 0 miles on it, stage 3 patriot heads, and a fairly large custom grind cam in it... for a very reasonable price. it is going in as i type this... hopefully it will be running by this weekend, and retuned by next week.
the head didnt look too terrible, but the piston did. probably since i drove it around my yard, then on and off a tow trailer and around the dealership with a valve in the cylinder clanking around.
i expect the new motor to be well over 500 rwhp on the juice.
stay tuned.
stay tuned.
9 Second Truck Club
Is there any evidence of valves hitting the piston on the other cylinders? Usually when a valve breaks like that it's because the piston hit it. I know the 4.8L has flat top pistons, and the short stroke degrades piston to valve clearance. Were you running LS6 springs?
