Wtf...
Old 04-19-2011, 10:51 AM
TX Tahoe Z71's Avatar
Spray some Kroil penetrating lubricant in there a few times and let it soak a day or two. Probably have to order it online, but much better than PB Blaster at breaking loose frozen bolts. Vice grip the ones you can get to, drill out the others like said above.
Old 04-19-2011, 10:33 PM
06murder's Avatar
just scared bout messing up the head...i dont work on motor everyday i work on the body parts of cars its a bit nerv racking
Old 04-19-2011, 11:13 PM
Mod with training wheels
smokeshow's Avatar
Whatever you do, just take your time. Don't be hasty with it at all.
Old 04-20-2011, 12:15 AM
06Sierra2's Avatar
or just order some after market heads!!
Old 04-20-2011, 12:56 PM
GFYS and STFU
Spoolin's Avatar
Can't he just drill out the bolt hole and heli-coil it?
Old 04-20-2011, 01:14 PM
PT's Slowest Truck
budhayes3's Avatar
That'll work too...I'd try drilling the bolt out and saving the threads first, but if that fails a heli-coil will work just fine
Old 04-25-2011, 03:46 PM
CodyBoy's Avatar
When I disassembeld mine there was a ex manifold broke off in the head. The very back one on # 7.
It was broke from the factory. The manifold had never had the bolt head contact the surface.
Never had an exhaust leak from it though. 165K miles.
The machine shop is drilling it out right now. Hope its ready soon. Getting itchy fingers and I want my truck back.
Old 04-25-2011, 04:57 PM
PT's Slowest Truck
budhayes3's Avatar
It probably broke after some time of heating and cooling, expanding and contracting, etc. Real common on the GENIII engines. Everybody that I know with a 99+ Chevy truck, who kept the factory manifolds, ends up with a broken bolt or two, and it's usually the rears that go first Lucky for me, I swapped my manifolds out for some headers early on
Old 04-25-2011, 11:20 PM
06murder's Avatar
thanks guys for the advice but im just going to get my buddy to do it for me,50 bucks ynt hes putting new gasket in both head n bolting them for me n all the other stuff for 200.....
Old 04-26-2011, 12:16 AM
HEADHUNTER92's Avatar
if your not familiar with doing it and your buddy can do it....smart move......ive done it at the shop i work at but its always on the bench.... 1/8 drill bit and an easy out after sprayed with the magical kroil oil(best stuff ever made for that) and a propane torch the expand the head just a tick and they come right out. by the way if you want a machiinist that is/has produce some serious horse power check out www.timzeppengines.com he definately can make em run. and that aint no b.s.
Quick Reply: Wtf...
