Lightning intercooler pump??
Anyone know the flow rate on this pump. I'm going to build an intercooler for my truck and thought this would be a good choice for the pump since its OEM.
http://www.performanceparts.ford.com...tKeyField=6199
Allright, basically all I got on it is it's a Bosch pump and the flow rate will be determined by your I/C setup it's self. You can get the part number off it from Ford and research that to find the actual GPH it will move. Hope that helps.
Did you ever get this setup working? I ended up getting a bosch pump, but I cant get mine to move any fluid. I know the pump works, but no movement.
rednekferlife101
09-14-2015 05:27 PM
