NEED HELP install lower pulley!!!
Installing a lower pulley on an 2000 lightning and need to see pics or step by step instructions to install pulley including needed tools. NEED IT ASAP SOMEBODY HELP!!!!!!!!!!!
Check this out. Should find it usefull.
http://www.rpmoutlet.com/asp54blowerinstruction.htm
Rember. The center bolt is LEFT HAND THREAD!!
If the truck is a virgin to a pulley, taking off the stock pulley is a major PITA, takes alot of muscle to break it loose, and it is a left hand thread, make sure the tranny is locked or you will just be spinning the crank
sorry i sound dumb but I dont know crap about autos or trucks. How do I lock the tranny and WTF is left hand thread. Again sorry i dont know crap about anything but ls1
there should be a lil strap that comes with the pulley that uses one of inspection cover bolts and one of torque converter nuts to lock trans from turning. i dont like the idea of using a wrench to hold it still. left handed thread means that u loosen it by turning clockwise instead of counterclockwise. right backwards from a normal bolt. hope that helps
therock
07-25-2015 09:23 AM
bassani, bolt, bolts, bottom, clockwise, counterclockwise, crank, ford, instale, install, installing, lightning, llightning, lower, pulley
