Member made Tools & Parts Classifieds Need permission to sell in this section...see section guidelines
Disk Brake Brackets for 15” Wheel Conversion
Old 05-03-2015, 08:13 PM
  #81
javzh's Avatar
does the russell SS line bolt right up without any modifications? part number ?
javzh is offline
Old 05-03-2015, 08:18 PM
  #82
GMCtrk's Avatar
See post #79.
GMCtrk is offline
Old 05-03-2015, 08:43 PM
  #83
oakley6575's Avatar
A simple L bracket off of the caliper bracket would hold the brake lines. Either bolted or welded. These are cut from 6061 T6 so if you are going to weld them, you'll need an AC welder.
oakley6575 is offline
Old 05-03-2015, 08:49 PM
  #84
GMCtrk's Avatar
I don't weld, but I was just saying it would be a nice addition to the product for a bolt on bracket. Not that anything is happening to the brake line without the bracket, but there is some slight movement.
GMCtrk is offline
Old 05-09-2015, 06:41 PM
  #85
iamkeniff's Avatar
Factory brake lines massaged to fit on mine. I routed the oem steel lines as far as i could to make sure they had supports. I can make a bracket for the drivers side if it is a must. Yet i dont see it as an issue.
iamkeniff is offline
Old 05-10-2015, 11:02 PM
  #86
iDEALS1's Avatar
This is how I mounted my brake lines. I just cut the old brackets off of the old backing plate and welded them straight to the axle. Worked perfect.
iDEALS1 is offline
Old 05-21-2015, 02:53 PM
  #87
iamkeniff's Avatar
^^^^ that is pretty dang simple! What ss hose kit is that?
Old 06-12-2015, 11:22 AM
  #88
907rs's Avatar
Do you have any of these in stock now? I'd like to get a couple of sets.
907rs is offline
Old 06-20-2015, 12:36 AM
  #89
Silveradorst07's Avatar
Also interested on a set. PM me
Silveradorst07 is offline
Old 06-21-2015, 02:39 PM
  #90
oakley6575's Avatar
PMs replied to. I have a few in stock right now.
Quick Reply: Disk Brake Brackets for 15” Wheel Conversion
