Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
2.2 missfire question
Old 04-09-2009 | 10:03 PM
BluLS1's Avatar
Default 2.2 missfire question
i know this is far from performance but i thought i'd give it a try.
i just aquired a 98 gmc sonoma with a 2.2 5spd
the guy said it started acting up and runing rough after he went though a deep water/mud hole.
well it miss fires bad, you would almost think it had a monster cam. it will only rev up to 2500 maybe 4000 if your lucky but mostly stays around 2500
new ngk plugs, new wires, good compression on all 4,
i got to thinkin that the coil packs are down low and maybe got drowned out but they checked ok with an ohm meter. the only other thing i could think it could be is the ignition control module that the coils go on.
any other ideas here?
i'm pretty sure but not 100 percent that its not a fuel problem seein that it started this after he went to the water hole.
Old 04-11-2009 | 02:24 AM
BluLS1's Avatar
anything???
okay so i put on new coil packs and an ignition module and still not better.
it was throwing a map sensor code. could the map sensor cause it to misfire bad?
with it running i pulled off the wires to each cyl to try to find which one is missing and the only one that didn't change was no. 4 cyl. i know its getting fire so its just about got to be a fuel problem like a stopped up injector on no. 4?
also it is putting out fuel smoke every so often.
JordanH
12-25-2015 08:32 AM
TAPyvehc93
09-12-2015 08:19 PM
spooneralmighty
09-11-2015 02:28 PM
chevstang421
09-10-2015 09:16 AM
carid
09-10-2015 09:07 AM
Quick Reply: 2.2 missfire question
