Budget reg cab sportside s10 4.8l / nv3500 build
#83
Alright so I tugged on the metal rod and nothing happened. Then I removed the snap ring and tugged and the entire guts came out. Did you put the spacer in behind all this or did I go too far?
#85
Figured. Oh well hopefully I can put this brand new one back together and get my neighbor to cut and weld a piece in to lengthen it. Or figure something else out. Let the experimenting continue!
#86
Well got the rod out. Took about 20 minutes with tiny flat heads to push the prongs out of the way. I think if I just cut and have a small piece welded in the rod it will be good to go.
dantheman1540 (02-16-2020)
#89
The whole swap went really smooth and was allot easier the I expected. Only problem now is I’m out of projects and bored. Been thinking about picking up a rcsb 1st gen S10 to swap with what ever gen 3 motor I can find and build a th400 for it and build a turbo setup for it. Figured it something I could build, tune and turn around and sell down the road for a little profit.
#90
Went to pick a part today to finally source a smaller radiator overflow and found a nice little Honda one that should get the job done and doesn’t take up any room. Also picked up a Chevy Colorado front lip and fit it onto the S10. It was a bit wider then my S10’s bumper but I was able to take a heat gun and drill holes in it to use bolts and nuts to mount it up. Got that stuff and some bravada ***** for $20 total. Pretty happy with how the lip looks. Might need some side skirts now.
