Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
Budget reg cab sportside s10 4.8l / nv3500 build
Old 02-15-2020 | 12:09 PM
  #81
T-RevMotorsports's Avatar
Yeah just give it a little tug tug. I pulled my master off without touching the rod or the pedal just twisted it clockwise and it popped right off
Old 02-16-2020 | 04:57 AM
  #82
smokinlmm's Avatar
Pretty work! I love this build!
Old 02-16-2020 | 04:28 PM
  #83
dantheman1540's Avatar
Alright so I tugged on the metal rod and nothing happened. Then I removed the snap ring and tugged and the entire guts came out. Did you put the spacer in behind all this or did I go too far?
Old 02-16-2020 | 04:47 PM
  #84
You’re looks allot different then mine. You might have to cut the rod and lengthen it slightly or configure a spacer that goes between the rod and clutch pedal.
Old 02-16-2020 | 04:56 PM
  #85
Figured. Oh well hopefully I can put this brand new one back together and get my neighbor to cut and weld a piece in to lengthen it. Or figure something else out. Let the experimenting continue!
Old 02-16-2020 | 05:32 PM
  #86
Well got the rod out. Took about 20 minutes with tiny flat heads to push the prongs out of the way. I think if I just cut and have a small piece welded in the rod it will be good to go.
Old 02-16-2020 | 06:07 PM
  #87
Nice. I would find something you can use as a sleeve then cut it and put it in the sleeve and weld both sides.
dantheman1540 (02-16-2020)
Old 02-16-2020 | 06:59 PM
  #88
chevymec's Avatar
Quick work!
Old 02-16-2020 | 07:30 PM
  #89
The whole swap went really smooth and was allot easier the I expected. Only problem now is I’m out of projects and bored. Been thinking about picking up a rcsb 1st gen S10 to swap with what ever gen 3 motor I can find and build a th400 for it and build a turbo setup for it. Figured it something I could build, tune and turn around and sell down the road for a little profit.
Old 02-17-2020 | 08:15 PM
  #90
Went to pick a part today to finally source a smaller radiator overflow and found a nice little Honda one that should get the job done and doesn’t take up any room. Also picked up a Chevy Colorado front lip and fit it onto the S10. It was a bit wider then my S10’s bumper but I was able to take a heat gun and drill holes in it to use bolts and nuts to mount it up. Got that stuff and some bravada ***** for $20 total. Pretty happy with how the lip looks. Might need some side skirts now.
Quick Reply: Budget reg cab sportside s10 4.8l / nv3500 build
