Picked up my LQ4, first part to my build
#21
Okay so... i ordered mahle piston kit through summit this morning... those guys are awesome they price matched so i got an awesome deal. i will soon be ordering all clevite bearings. and now im curious on the main cap bolts... can i used stock main bolts with my build? dont plan on taking apart the bottom end. will be using arp rod bolt for sure tho
#27
arp rod bolts has been my dilema.... from what i have read is that when just changing bolts out and putting arp inplace of oem there seems to be no problems... but if its a complete rebuild there seems to be some hesitation..im just worried about the arp's putting too much clamping force on the cracked cap design rods... any insight on this or should i not be worried
#28
What power level is your goal? Are you using any power adders? Stock bolts in the bottom end are good for quite a bit.
If you decide on ARP rod bolts, or ARP mains, I'd recommend you have your machine shop check to see if any resizing or align-honing is necessary. Seems like there's more possibility of "distorting" the bearing journals with the ARP's.
