Spraying the lil 4.3... got ???s
Originally Posted by ChevyThunder17
That's correct; Central Point Injection.
Should be about 80+ psi. But I don't think you can remove the vacuum for the FPR.
Ok i was just wondering...
So when im tryin to find out what jets to use what Fuel PSI do i need to use?
You'll probably pull the fuel from that schrader valve, so 80 psi is what I'd base it on for the fuel nozzle.
I think i can do the COS and run it to pull timing when the arm switch is turned on... i think...
Originally Posted by Dogsofjune
That's not quite correct. It's CSFI. Central Sequential Fuel Injection on the '96 and newer 4.3's.
It's a really shitty system if you are looking to make power. You have no ability to up your injector size and the fuel pressure is already through the roof.
I was thinking of the 92-95's for some reason; yes, it's sequential, not port.
Fortunately, some of us with the 4.3 S-10's have overcome the fueling issue so we have the potential to make some power.
thompson
12-27-2017 06:48 AM
