MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
03 4.8 turbo silverado SDPC cam w/MBRP 4" exhaust
Old 06-02-2014 | 04:42 PM
fastjweb's Avatar
Default 03 4.8 turbo silverado SDPC cam w/MBRP 4" exhaust
Dont bash me too bad, truck is only on 4-5lbs right now until the 80e goes in. 3.42s on 295/40/20's. Truck is full weight and ran a best of 14.008 at 100.8 with a 2.28 60ft. Cant build boost yet at the line. I dont think its bad for small cam and its boost level.
A vid of the exhaust, and some fun on some back roads with the gopro.
GOPR0673 - YouTube
My Movie10 - YouTube
track pass me vs mazda speed 3 lol (with 2 1/4 single flowmaster exhaust)
mypass - YouTube
Old 06-03-2014 | 07:50 AM
foose04's Avatar
Sounds good. Keep dialing it in and the track times will only get better.
Old 06-03-2014 | 04:00 PM
fastjweb's Avatar
Thanks Foose, im sure it will come to life when i turn it up, but its even a fun street truck the way it is. I was actually going to ask you about what you did with your electronic assist brakes. I dont know if it was just 03 that had it, or 04 too. I think the boost is pushing the vaccum out. Did you install a check valve? I figure even now if I was able to build a few pounds on a drag radial, it would be mid 13's easily. Thanks
Old 06-03-2014 | 06:16 PM
kelsey_canard's Avatar
Good runs man. Turbos aren't as easy to setup as everyone thinks. You see a bunch of trucks on here running well, and dont really realize how much work goes into it. I'm learning that too. Stay with it bud.
Old 06-03-2014 | 06:23 PM
fastjweb's Avatar
Thanks man, yeah I went from crew cab running 12's back to 16's and back down to low 14's lol. I really think when the trans and converter go in, and turn the boost up to 10-12 it should run pretty well. I may take it back one more time with the new 4" exhaust and see if it drops some more before I do anything else. It still has the stock trans, converter, and rear end, so Im pleased at this point.
BoostedBowTie
01-03-2020 07:46 PM
Rafe19
10-18-2016 01:27 AM
chopperloco
07-10-2016 11:45 PM
Suburban2500
07-19-2015 05:50 PM
Cowboy17
07-09-2015 09:22 PM
