1/4 mile passes
Import Moderator
Originally Posted by trever1t
Definately
I understand frustrated, I was stuck at 15.0 and couldn't break 14 with the setup I was running, na.
Keep at it. I drop time amolst every trip I make to the track
Import Moderator
Originally Posted by ChevyThunder17
What was your tire pressure at? Over 20 psi? If so, air those puppies down.
Try lowering tire pressure, like 1 pound at a time. Bump in to light the top light, pump up the brakes real good, and try to leave at arounbd 1000, or so. Also, you need to do a good hard burnout to make sure you don't have water on your tires. You goin to Quaker city this Fri? I'm thinking of going.
Import Moderator
ok, ya i didnt touch tire pressure at all last night, i should have been
no i dont think so, im gonna try to stay away from racing a lil to i atleast get the trans built. i dont know if they are doing testntune this friday are they?
hey man good runs! Defineatly go with some lower tire pressure, you got yourself some good ET streets so heat them up real good and they should stick real nice. Congrats on the low 14 second passes and get that thing into the 13's!
BennyB
08-01-2015 08:48 AM
