1.40 to 1.60 60" on caltrac's? Come in here
i installed a coil over spring from autozone that i purchased for 40 dollars flaco used them on lil sis also he told me to install them and ive been gettin 1.52 to 1.48 60ft with caltracs flaco adjusted them for me and gone as fast as 6.56 1/8 mile at 108 mph and 10.44 @ 109 letting off
8 Second Club
firstnof all what setup do u have on rear? is it a flip kit or? how much pinion angle do u have on it...on all the trucks i have done all have a flip kit and c-notch..and u need to have the bars as straight as possible
Right now I have caltrac's non-flip kit , removed one leaf and stock springs and shocks. Pinion angle I'll need to check, what pinion angle should I target?
The caltracs I don't think they are straight because when I tried to take all the load off it would only go a full turn after they came if the leaf.
I'd like to try that Coilover spring if it's a bolt in type deal an herd front v6 springs will help aswell as I am just running 90/10's up front
8 Second Club
Thanks for posting up flaco.
when u do a flip kit then you can adjust the bar to be staright as possible as it will help out alot...
pinion angle i always run it at -4*
Flaco
Gotcha, with what I have now what sock you recommend for the rear?
with it not having a flip kit, your never gonna get it to squat like our trucks do (flip kit ones) its gonna still plant the rear end down when you apply some power but its gonna raise the rear up as u do so...i have had some customers trucks sixty in the 1.4 without having a flip kit but their all nitrous and have to hit it hard out of the hole...
Flaco
Flaco
