MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
Beastmode's Project!
Old 09-26-2008 | 10:57 AM
  #141
7845's Avatar
Banned
he is copying my exact setup...EXACT. ive been there and done that and it did nothing for me. i switched from the truck with 8.1 injectors to the LS6 intake with svo red tops and noticed zero difference on the track. my duty cycle numbers were alot nicer though. a complete wast of money so far but atleast it has me ready for a street warrior intake or a fast 90 or 92 in the future.
identical setups dont always work out the same. I understand what your saying but there could of been things like the tune, the weather, the track and etc not allowing the full benefit of the intake. the truck intake it restrictive and on his RCSB he will notice a difference. Its a proven intake over and over again.
Old 09-26-2008 | 11:19 AM
  #142
TXsilverado's Avatar
his truck is an ecsb, with the same tuner...actually its probably the same exact tune. when i say exact i mean EXAXT carbon copy of my trucks setup. heads, gaskets, injectors, cam, pushrods, blah blah....it was suposed to have the same converter but frank screwed him over at fuddle.
Old 09-26-2008 | 11:30 AM
  #143
7845's Avatar
Banned
its a RCSB...he is seling the extended cab.... so combos changed!!!!! ya him listening to getting a fuddle was a joke. he should of stayed his Yank 4k he had. not to mention he is thinking of different cam. TX your setup works for you but billy boy changes his mind alot.
Old 09-26-2008 | 01:18 PM
  #144
beastmode's Avatar
Import Moderator
Technically the combo hasnt changed aside from the converter... just because its a RCSB as opposed to the ECSB doesnt mean anything aside from weight factor. My motor will still be setup the same as his and what not.
Old 09-26-2008 | 02:05 PM
  #145
03sierraslt's Avatar
So is your converter built for the wieght of your EC? Now your putting it in a SC?
WTF is going on
Old 09-26-2008 | 02:43 PM
  #146
actually if i had a single cab i would have a bigger cam and different head gaskets. but if the money is already spent no point in changing things now. the gains wouldnt be worth it. im thinking your guaranteed an 11 second pass if that yank converter performs with a scsb.
WTF is going on
i dont think the ecsb vs scsb weight will make much difference in the converter.
Old 09-26-2008 | 03:22 PM
  #147
Wheatley's Avatar
Truck Sponsor
When your truck gets goin,it is gonna run hard
Stuart is right,damn near the same exact tune and it works AWESOME
you'll see
Old 09-26-2008 | 04:38 PM
  #148
beastmode's Avatar
Import Moderator
you'll see
Old 09-26-2008 | 10:50 PM
  #149
7845's Avatar
Banned
a tune setup for texas wont perform nearly the same as a tune for the mountains for PA. also the tracks down in TX arent like the tracks up here. the tracks here are much slower. his setup to see 11s will take much more then what ppl in tx need to run. Higher elevation always plays a factor in times
look at it like this bill....there are two cars local with same setup as yours and arent breaking 11s!!!!!!!!!! what makes you think a truck with same parts going to run faster?
Old 09-27-2008 | 06:21 PM
  #150
AeroKing's Avatar
but if the LS6 intake makes no difference in TX, i'll put money down saying that it wont make a difference in PA. Go with the proven tested setup.
Quick Reply: Beastmode's Project!
