Beastmode's Project!
#32
put a light coat of spray on copper gasket on the gaskets for a little extra cheap insurance.
oh and wear leather gloves while cleaning the blolck...there are tons of shap edges to lose a finger on spray some wd40 in the piston holes if you havent already. i had some surface rust appear FAST cuz i tried to use penetrating lube instead of wd40. dummy me!
#35
dang i knew i shouldnt have bought nitrous!!!!! i hate it!! looks like we will have a very close setup and times between the three of us......lol
hey TX whats your times like in this hotter weather??
#36
Import Moderator
EFF your method!! This is what I did....
First took the big stuff off with a razor blade.
Then I sprayed some carb cleaner all over that bad boy and scrubbed the **** outta it with a scotch brite pad.
Then after that was all said and done I sprayed some WD-40 down in the piston holes and all over the pistons to protect from surface rust
#38
has beastmode released the specs of his setup to everyone else yet? i would hate to let the cat outa the bag. it may be me beastmode and charlie wheatley only right now. its guna run great!
i havent gotten to run it in the heat yet. got the heads on during the winter months. ill be back out there soon with my caltracks and some more tuning. theres more left in the tune. me and charlie threw a 10 minute tune in there and rushed straight to the track so we werent late.
