MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
DMH installed. Sound clips inside.
Old 02-20-2010, 09:27 AM
D_reks{5.3}'s Avatar
Default DMH installed. Sound clips inside.
Got my cutout on 2 days ago and got a couple idle/rev clips..
If you havent seen the new exhaust set up here is the link:
https://www.performancetrucks.net/fo...d.php?t=457259
Cold Start: about 30-40 secs in is when she starts to lope.
Warm start, Idle/Rev:
Old 02-20-2010, 11:03 AM
Baltimore Whore
Mangled03gmc's Avatar
You didn't get it on 2 days ago you lying ****.. Sounds good for sure
Old 02-20-2010, 01:09 PM
SLOXCAB's Avatar
sounds real good man and i love your slippers
Old 02-20-2010, 01:14 PM
GMCtrk's Avatar
sounds nasty, but that cutout is hanging down way too low for my liking.
Old 02-20-2010, 01:29 PM
Baltimore Whore
See D-rock told you,you should have gotten the low profile cutout from me instead of that one
Old 02-20-2010, 01:30 PM
SLOXCAB's Avatar
are you able to reclock it out of the way??
Old 02-20-2010, 02:58 PM
Thanks guys. I knew someone was going to say something about my slippers..
Its pretty low for my liking too, Its about even with trans. crossmember. If I turn it the other way it hits the frame and wont line up with screws, Thats the best i could do. I have to get back under there to zip the wire in a couple spots so i will double check and see if I can get turned another way.
Old 02-20-2010, 03:14 PM
SILVERADO11's Avatar
sounds sweet! gotta get me a cut out.
Old 02-20-2010, 03:42 PM
SLOXCAB's Avatar
i had to reposition my y pipe so the cutout wasnt hanging low
Old 02-20-2010, 03:49 PM
Y pipe is up pretty high, If I could face the cutout the right way without hitting the frame it would be good and you wouldnt even see it.
Quick Reply: DMH installed. Sound clips inside.
