header noise
header noise
Im trying to figure out if this is normal header noise or if something has gone out of whack. Before I ever messed with the exhaust (all stock) this motor was quiet as can be. All of my exhaust bolts are tight as can be, I've triple checked. It's like a light knocking noise that's in rhythm with the engine...but it's loud...it can easily be heard over the cutout and is loudest on the passenger side.
View My Video
View My Video
Does it sound like a lifter? Did you use the stock manifold gaskets or the paper header gaskets?
I'd check the gaskets. Blew one out on the driver side once and you'd swear I bent a pushrod
They are the original stock MLS gaskets. The ones on the drivers side did come apart ( the three pieces came apart) but I don't see how that would affect anything. I don't see how these metal gaskets could go bad either. I sprayed soap water all over the flange area and there was no leaks
I would look into the gasket's as well. However it's hard to tell from a video, it could be a bad lifter...
My springs make noises like I've got an exhaust leak at the collectors down at the bottom but i know they aren't leaking. I'm thinking about taking the headers off and using new header gaskets and switching over to 10-30 oil. But, when I get the money I'm gonna get some worked over heads and swap to ls7 lifters and better springs, so hopefully my valvetrain wont be so damn noisy.
