MULTIMEDIA (truck related) Post your Truck pictures and videos (PG-13)
header noise
Old 03-07-2009 | 09:30 PM
GMCtrk's Avatar
it's got pac 1218's and hardened 7.375's. But I had this noise before the head and valvetrain swap. It all started with the headers but I can't remember if it started right when i put the headers on. I would cap up my cutout so i could locate the noise easier, but i left it at the GTG about 250 miles away. It's supposedly being mailed back to me.
Old 03-07-2009 | 09:31 PM
charcold-bowtie's Avatar
Ive sworn to everything and everyone that since I put shorty headers on Ive had a leak. After talking to other people i think the cast manifolds just soak up that much noise. But thats my guess of things....
Old 03-07-2009 | 09:32 PM
viciousknid's Avatar
Where's the Beef?
Mine kinda tinks when I put it in gear or go from no load to load.
I've wondered if the Flange could be twisting enough to make noises?
And yea. Stock does absorb a lot of noise because they are so thick
Old 03-07-2009 | 09:48 PM
BlackGMC's Avatar
Resident Retard
it is your valves slapping shut... The bigger the springs the louder the valves shutting is... Also with headers the noise is loader cause the cast manifold soak up alot of engine noise....
Old 03-08-2009 | 05:17 PM
KevinF56's Avatar
yep. my pacesetters on my old truck had that header tick. you'll get used to it.
Old 03-08-2009 | 08:14 PM
00ChevyScott's Avatar
Wearin' da big hat
I'm still not used to mine
Old 03-08-2009 | 08:46 PM
KySilverado's Avatar
Mines even louder when I cold start it. Let it sit and idle for a few minutes and you can hear it progressively quieten down.
Old 03-08-2009 | 08:56 PM
GMCtrk's Avatar
I haven't found a cold start/running hot to make any difference in noise level.
Old 03-09-2009 | 12:37 AM
Mangled03gmc's Avatar
Baltimore Whore
Sounds ok to me, the more spring you have the louder it will be...
Old 03-10-2009 | 01:13 PM
nonecktribe's Avatar
its just your valvetrain your hearing...i thought the same thing that maybe something was wrong but its just that when you change your airbox/headers/valvetrain around you eliminate alot of the sound dampening that manufactures do for the "old people" so they can have a comfortable ride...hence why there is so much more power in them when you modify....it will take time to get used to but its normal...
Quick Reply: header noise
