Jake99 turbo 4.8 vs H/C/I LQ4 Z28
Jakes truck has a 150k mile '99 stock bottom end/heads 4.8, Isky triple 12 cam, ARP studs, MLS LS1 head gaskets, home built front mount Magnum 76mm turbo system, 4L80e w/shift kit and an Edge 3200 9.5" stall, 3.73 gears and 30" M/T drag radials. He was on 19#s of boost, 10.1 AFR, and 14 degrees timing.
The Z28 has a stock bottom end LQ4, PRC 215 heads, 233/239 cam, LS6 intake, Edge 4k stall, 3.42 gears and 315 Nitto NT555 tires.
First run Jake spins hard, second run, not so much lol
03regcab sierra
20
08-03-2015 12:11 AM
