Corvette brakes on 94 c1500
The spindles are similar from GMT800-up. Very different from GMT400. Good luck.
I mean, anything can be done if you throw enough effort, skill, and money at it...
Richard
Richard
zz454Chevelle67 (08-20-2021)
Nah I like them. I think the HC 1500 is the worst. I like the trail boss and RSTs. 2500 front end is hands down my favorite though. I think they have a cool look to them.
So, i found Wilwood 2" drop spindles require upgrade to radial mount brake calipers. I may be onto a solution. Now i have to find out if corvette calipers will mount directly to the Wilwood spindles. Is there a spindle thread?
https://wilwood.com/Spindles/Spindle...emno=831-15933
"Wilwood's C1500 Steel ProSpindle Kits contain a pair of one piece spindles and integrated steering arms for 88-98 Chevrolet & GMC 2WD C1500 Pickups, Blazers and Suburbans. Specifically designed for use with Wilwood's disc brake kits and with a 2.00” drop without affecting steering geometry."
Something tells me they're gonna say "No, the Corvette Z06 calipers will not work" - but it's just a hunch. You could still always ask. But, note from that page: "Cautionary Info Spindles (Pair) L/H & R/H. Can only be used with Wilwood Brake Kits"
Richard
Little shop mfg makes a bracket and kit to fit the new wilwood spindles iirc, also for the stock or mcghauys spindle. Aint cheap tho, but none of this kinda stuff is i suppose.
also have rear matching kits and more budget front and rear kits that use c4 or c5 stock style brakes iirc..
