need help with throttle linkage for 92 dodge truck with a 5.9
Registered User
I just swapped out a 92 for a 91 cummins 5.9 stock motor and fuel pump. I can't get the tranny to shift to overdrive and the turbo boost isn't there where it was . I have the old pump which was turned up still and may end up putting it on unless I can get some advice. I'm new to this stuff and on a learning curve still. The motor runs ok. oil pressure shows low and i suspect the sending unit or guage. the alt guage is not reading right although its charging. water temp is great. every thing seems to work. water in fuel light is on even after purgeing fuel. I'm headin out to change it right now. new filter time. any help of suggestions would help.
GreyChevy
07-07-2015 08:57 PM
Gadgetized
07-07-2015 04:40 PM
